Hello Guest it is October 21, 2026, 01:38:59 PM
Author Topic: stepperunitcalculatorbasics  (Read 19483 times)
« on: January 18, 2022, 04:55:44 PM »
I am having issues with this wizard function not working right now. I select the distance and speed and axis and when I hit the move button it doesn't move or seem to do anything. Is there something I am doing wrong or is there a known glitch with that particular wizard?
Re: stepperunitcalculatorbasics
« Reply #1 on: January 18, 2022, 08:39:32 PM »
If you have problems work with the wizard just don't use it and do it manual.
With that formula you can find what you want.
Current steps Per Unit / Distance actually traveled * Distance should travel = New Steps Per Unit
« Reply #2 on: January 21, 2022, 08:40:03 PM »
The machine needs to be enabled before trying to move it using the wizard. I know that is obvious but it's happened to me before and I was scratching my head for a while. lol
I created an updated steps per unit calculator a little while back that might make it easier.
The latest version download is in the 5th post down.
https://www.machsupport.com/forum/index.php?topic=43830.msg281953#msg281953
Just put the stepsCalc.mcs file in the Mach4 Wizards directory.
To use:
     - select the axis radio button; the current steps/unit auto fills in text box below radio buttons.
     - fill in the distance you want it to move in 'move distance'
     - fill in velocity in 'move velocity'
     - press incremental move and wait for machine move to complete
     - after the move, measure actual distance machine moved and fill in the 'actual distance' box
     - hit calculate
     - press set counts to set the new calculated counts/unit in the Mach4 control settings.
The wizard should update the settings for any child motors for the axis as well.
« Last Edit: January 21, 2022, 08:46:48 PM by compewter_numerical »
