Hello Guest it is October 22, 2026, 03:40:57 PM
Author Topic: Mach4 Lathe: Displaying spindle rotational angle?  (Read 14042 times)
Offline Azalin
  •  189 189
« on: December 23, 2021, 04:36:44 PM »
Is there a way to display the rotational angle of the spindle? I have an encoder on the spindle so it should possible.
Any ideas?
Thanks.
Re: Mach4 Lathe: Displaying spindle rotational angle?
« Reply #1 on: December 25, 2021, 12:01:14 PM »
check the mach4 videos there was a video on how to do it, I have all rotary cncs but i dont display that way but I do remember it was an option.
Jamie Doeren
Renegade carving Co LLC
Offline Azalin
  •  189 189
« Reply #2 on: December 26, 2021, 03:42:47 PM »
Offline Azalin
  •  189 189
« Reply #3 on: February 22, 2022, 04:54:57 PM »
I still need help with this.
« Reply #4 on: February 22, 2022, 09:51:24 PM »
I'm guessing that the encoder is actually an auxilliary encoder output from a servo?
What motion controller are you using?
You will need at least three spare inputs, A, B, Z. Mach can deduce a number from those input, and that number can be
manipulated to represent an angle in degrees or radians and then be displayed as a DRO.
Offline Azalin
  •  189 189
« Reply #5 on: February 23, 2022, 03:05:55 PM »
Hi Craig,
I have an incremental encoder attached to the spindle. I have index, A+, B+ A- and B-
« Reply #6 on: February 23, 2022, 03:11:53 PM »
what motion controller are you using?
Offline Azalin
  •  189 189
« Reply #7 on: February 23, 2022, 03:13:11 PM »
M16D with PoKeys 57E
« Reply #8 on: February 23, 2022, 03:19:13 PM »
OK, you are going to have to hook the encoder via to the PoKeys, I presume the PoKeys has MPG and/or encoder inputs.
The PoKeys will probably report to Mach in the form of a register. Open the register diagnostics and scan through the PoKeys registers until
you find it.
Offline Azalin
  •  189 189
« Reply #9 on: February 23, 2022, 03:28:18 PM »
Encoder is already connected and works great. Threading no problem.
I didn't know the existence of the Register Diagnostics plugin. I'll take a look.
Thanks.
