Hello Guest it is October 22, 2026, 04:18:45 PM
Author Topic: Mach4 Lathe: Displaying spindle rotational angle?  (Read 14053 times)
Re: Mach4 Lathe: Displaying spindle rotational angle?
« Reply #10 on: February 23, 2022, 03:34:43 PM »
I use an ESS and I imagine the PoKeys will at least be broadly similar.
Offline Azalin
  •  189 189
« Reply #11 on: March 19, 2022, 12:49:06 PM »
Hello again,
Thank you very much. And sorry for the late reply. I was busy with other things.
You are right. Found the encoder ticks in the regfile window. I noticed that the resolution of my encoder is too low. Only 400 ticks per rew. So it is actually a 100 PPR encoder? I need an encoder with much higher resolution to be able to cut large spur gears.
