Hello
Guest
it is
November 14, 2026, 02:42:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Soft limits
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Soft limits (Read 23000 times)
onescentpro
6
Newbie
Soft limits
on:
December 08, 2021, 04:34:25 PM »
Mach 3 will not let me turn on the soft limit icon. Every time I press it I get (Machine out of limits for soft limit activation.) I home in the upper right on my CNC. I have the machine coordinates set to 0.0000 for all axis's with the machine located where I would home it. I also have my soft limits set to 0.0000. I have been trying to get my soft limits set for a long time so I can use my machine with no luck because I can't seem to get the soft limits set. I have mechanical limit switches installed but when the trip I have to turn of the machine and move it off the limit switch. I don't know where I can set that so it backs off one the switch is tripped. Would rather use the soft limits.
Logged
TPS
2,627
Re: Soft limits
Reply #1 on:
December 10, 2021, 12:55:18 AM »
with Settings (screen) -> override limits you shold be able to jog off a limit switch.
soft limits are only working with machine coordinates, so you have to have reference switches and
referenced all you axis to use them.
Logged
Print
Pages:
1
Go Up
« previous
next »
