Hello Guest it is October 21, 2026, 01:38:59 PM
Author Topic: Mach3 has control but steppers run one direction only....help!  (Read 21659 times)
« on: December 08, 2021, 10:47:39 AM »
CNC setup.
Windows 10, Mach3, ESS Smoothstepper, (CNC4PC) C25S BOB and DIV-268N-5A drivers (3ea for X,Y,Z only), Stepper motors are 4 wire.
Mach3 Config in outputs:
X axis      Y axis      Z axis
Pul+ pin 2           Pul+ pin 4           Pul+ pin 6
Dir+ pin 3           Dir+ pin 5           Dir+ pin 7
Pul- pin GND   Pul- pin GND   Pul- pin GND
Dir- pin GND   Dir- pin GND   Dir- pin GND
Dir Low active is green checked for all axis.
Drivers have no connection to Enable+ or - ?
Has anyone else used the above drivers?
Thanks......dt
