Hello Guest it is November 22, 2026, 06:06:49 PM
Author Topic: Wiring Limit Switches  (Read 9468 times)
Offline olf20
  •  325 325
« on: October 18, 2007, 10:08:35 PM »
Hi all!
Just finishing up on my limit / home switches and was wondering if it is ok to use a common ground from the breakout board to my x minus and x plus limit / home switches. I know that all the grounds on the breakout board are common, but just was wondering if running a shielded cable with 3 wires was just as good as running one with 4 wires using one wire as ground for both switches.
Thanks for any help!!
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Re: Wiring Limit Switches
« Reply #1 on: October 19, 2007, 02:14:13 AM »
Yes that should work just fine.
