Hello Guest it is November 13, 2026, 05:01:06 PM
Author Topic: Connecting Pokeys57CNC with CNC4PC C4 Charge Pump  (Read 15207 times)
« on: October 14, 2021, 02:29:16 AM »
I'm looking for confirmation that I understand the wiring between these two units. From what I can see I run a wire from pin 45 on the DB25 connector to Pulse IN terminal on the C4 then from the Pulse OUT terminal on the C4 I run a wire to any of the ground terminals on the DB25 connector.
I would then need to go into the pulse engine status/control settings abd tick the Enable pulse engine, Enable safety charge pump output and make sure it is set at pin 45.
Is this correct?
Splint
