Hello Guest it is October 25, 2026, 05:54:17 AM
Author Topic: LINE 0: NO SPINDLE SPEED SET IN G95 MODE  (Read 5606 times)
« on: October 09, 2021, 05:38:39 PM »
Why do I get this error when I do not control the spindle with Mach4 ?
And, I do not see a G95 entry in the .TAP file
Offline thosj
  •  542 542
Re: LINE 0: NO SPINDLE SPEED SET IN G95 MODE
« Reply #1 on: October 13, 2021, 05:43:28 PM »
Just for curiosities sake, change S 24000 to S24000.
G95 is Feed per revolution mode. usually used on lathes. You likely aren't using feed per revolution with feeds of F50.0 and F20.0 at 24000 RPM's!!
« Last Edit: October 13, 2021, 05:48:16 PM by thosj »
Tom
