Hello
Guest
it is
October 25, 2026, 06:00:21 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
LINE 0: NO SPINDLE SPEED SET IN G95 MODE
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: LINE 0: NO SPINDLE SPEED SET IN G95 MODE (Read 5608 times)
canewb
2
on:
October 09, 2021, 05:38:39 PM »
Why do I get this error when I do not control the spindle with Mach4 ?
And, I do not see a G95 entry in the .TAP file
Logged
thosj
542
Re: LINE 0: NO SPINDLE SPEED SET IN G95 MODE
Reply #1 on:
October 13, 2021, 05:43:28 PM »
Just for curiosities sake, change S 24000 to S24000.
G95 is Feed per revolution mode. usually used on lathes. You likely aren't using feed per revolution with feeds of F50.0 and F20.0 at 24000 RPM's!!
Last Edit: October 13, 2021, 05:48:16 PM by thosj
Logged
Tom
Print
Pages:
1
Go Up
« previous
next »
