Hello Guest it is November 13, 2026, 05:01:33 PM
Author Topic: How to monitor the rotation speed of the spindle with Mach4 ??  (Read 6133 times)
« on: September 13, 2021, 06:23:46 AM »
Hello everyone.
The INDEX LED does not blink. Please tell me the solution.
I am,
The Hall IC DN6851-A is connected to the BOB input terminal (Port3 # 10).
The setting of Mach4 maps Port3 # 10 to INDEX.
You can check the On / Off of Port3 # 10, but the INDEX LED in the red frame does not blink.
Can anyone please tell me the solution?
Thanking you in advance.
Offline MN300
  •  306 306
Re: How to monitor the rotation speed of the spindle with Mach4 ??
« Reply #1 on: September 13, 2021, 07:53:25 AM »
Have you checked the output of the sensor with a voltmeter? The DN6851-A hall effect sensor you have used is an alternating magnetic field type. The magnetic field it sees needs to change between as least -20 mT to +20 mT. In other words, it needs to see both the North and South pole of the magnet to operate.
« Reply #2 on: September 13, 2021, 04:54:02 PM »
Hello Mr.MN300.
Yes, I confirmed with a tester.
On / Off.
And Port3 # 10 on the diagnostic tab flashes.
Please look at the photo.
Is my Mach4 setting correct?
