Hello Guest it is November 13, 2026, 09:30:07 PM
Author Topic: MACH4 G31 MOTION WILL NOT STOP ON PROBE CONTACT  (Read 9167 times)
« on: August 27, 2021, 12:40:32 PM »
Hello,
I am running Mach4 with Pokeys57CNC
Sorry to post a new topic on G31.  I've tried searching the forum archives and can't find a similar problem / solution.
The problem is when I run this gcode command in the MDI (as a test) the z axis does not stop on probe contact.
G31 Z-10 F50
I can run probing with no issues using the Probing Wizard.  Also the Touch light indicates contact during the move (using the gcode above).
Not sure what I am missing.
Anyone else had this issue?
Thanks.
Offline smurph
  •  1,575 1,575
Re: MACH4 G31 MOTION WILL NOT STOP ON PROBE CONTACT
« Reply #1 on: August 29, 2021, 03:49:52 PM »
Since probing is a real-time process, it must be handled entirely by the motion controller.  So I would investigate the settings of the Pokeys.
Steve
« Reply #2 on: August 30, 2021, 03:49:10 PM »
Thanks Steve
Offline gorf23
  •  190 190
« Reply #3 on: August 31, 2021, 12:43:51 PM »
I haven't had any probing problems with the pokeys57CNC make sure you are wired to pin 19 on pokeys and on some of the older boards you need to add a i think pullup resistor to pin 19  but been a while and don't remember for sure, the only drawback for me is it won't work with more that one probe connected..
Offline smurph
  •  1,575 1,575
« Reply #4 on: August 31, 2021, 03:00:39 PM »
Wow.  Good information.  Thanks!
Steve
« Reply #5 on: August 31, 2021, 06:04:25 PM »
Thanks gorf23!
Yup wired on pin 19.  Usually I don't have a problem.  It seems at times either Mach4 or Pokeys "looses itself"  I can't quite figure out how or why.
« Reply #6 on: August 31, 2021, 10:00:07 PM »
more then 10 machines ,all pokeys,all have probe ,never had problems,folow pokeys instruction
