Hello Guest it is October 04, 2026, 10:02:42 PM
Author Topic: Down load Gcode fail  (Read 19668 times)
« on: August 23, 2021, 05:47:12 PM »
Have used Vectric with Mach3 for many years without problems. Recently gcode would not download. This is a text file and noticed the file heading  where the gcode text file was to go was *tap. Changed this to all files *txt*   and download then worked fine. Upon moving to the next project the * tap returned. How do I permanently get the file type to return permanently to text. I have always manually downloaded the gcode text file. Dowmload direct to machine has never worked, how is this feature set up.
  •  9,374 9,374
Re: Down load Gcode fail
« Reply #1 on: August 24, 2021, 12:50:14 AM »
Its a little quirk in so far as the load file type is stored in your <profile> .xml file which is only updated when Mach3 is shut down.
Set 'File of type' to (*.txt) then load your .txt file. Shutdown then re-open Mach3. It should now be set for loading *.txt files.
(there are probably other ways of doing this but one method is as good as the other)
