G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: woodturner170 on August 23, 2021, 06:47:12 PM
Have used Vectric with Mach3 for many years without problems. Recently gcode would not download. This is a text file and noticed the file heading where the gcode text file was to go was *tap. Changed this to all files *txt* and download then worked fine. Upon moving to the next project the * tap returned. How do I permanently get the file type to return permanently to text. I have always manually downloaded the gcode text file. Dowmload direct to machine has never worked, how is this feature set up.
Its a little quirk in so far as the load file type is stored in your <profile> .xml file which is only updated when Mach3 is shut down.
Set 'File of type' to (*.txt) then load your .txt file. Shutdown then re-open Mach3. It should now be set for loading *.txt files.
(there are probably other ways of doing this but one method is as good as the other)
