Hello
Guest
it is
October 21, 2026, 06:01:26 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Start Mach4 in Screen Editor
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Start Mach4 in Screen Editor (Read 10738 times)
Cbyrdtopper
985
on:
August 13, 2021, 09:39:03 AM »
I have messed up my PLC script bad enough that Mach4 won't open. I can't remember how to open Mach4 in the editor mode. Anyone remember how?
Tried to enable some PMC code and it really didn't like it... so now I can't open Mach4 even if restore a previous backup.
Chad Byrd
rhtuttle
575
Re: Start Mach4 in Screen Editor
Reply #1 on:
August 13, 2021, 09:46:43 AM »
C:\Mach4Hobby\Mach4GUI.exe /pnameofprofile /e
Cbyrdtopper
985
Reply #2 on:
August 13, 2021, 09:56:45 AM »
I'm in industrial, but I assume that should still be ok.
Also, I can't figure out how to get this to work.
Do I rename the Mach4GUI? Or rename my profile?
Chad Byrd
rhtuttle
575
Reply #3 on:
August 13, 2021, 09:59:02 AM »
create a shortcut
Cbyrdtopper
985
Reply #4 on:
August 13, 2021, 10:02:31 AM »
Still Lost.
I cannot use "/" while renaming anything.
Chad Byrd
rhtuttle
575
Reply #5 on:
August 13, 2021, 10:05:47 AM »
After creating a new shortcut(named whatever you want,(eg.'Open M4 in editor') right click and select properties. It is in the 'Target' property that you put the aforementioned string.
Cbyrdtopper
985
Reply #6 on:
August 13, 2021, 10:28:15 AM »
I must have really screwed something up. It still won't open and tells me that I have something wrong with the PLC Script.
C:\Mach4Industrial\Mach4GUI.exe /p OD_Grinder/e
Here is the path that I'm using.
Chad Byrd
Cbyrdtopper
985
Reply #7 on:
August 13, 2021, 10:29:33 AM »
Ok. So I made a copy of the Mach4GUI and just put the property of "/e" in the line and it allowed me to open into the screen editor.
Chad Byrd
Cbyrdtopper
985
Reply #8 on:
August 13, 2021, 10:31:46 AM »
Thanks RT!
That'll do it for me. Got it taken care of!
Chad Byrd
Print
Pages:
1
Go Up
« previous
next »
