Hello Guest it is October 21, 2026, 06:47:49 PM
Author Topic: Start Mach4 in Screen Editor  (Read 10743 times)
« on: August 13, 2021, 09:39:03 AM »
I have messed up my PLC script bad enough that Mach4 won't open.  I can't remember how to open Mach4 in the editor mode.  Anyone remember how?
Tried to enable some PMC code and it really didn't like it... so now I can't open Mach4 even if restore a previous backup.
Chad Byrd
Re: Start Mach4 in Screen Editor
« Reply #1 on: August 13, 2021, 09:46:43 AM »
C:\Mach4Hobby\Mach4GUI.exe /pnameofprofile /e
« Reply #2 on: August 13, 2021, 09:56:45 AM »
I'm in industrial, but I assume that should still be ok.
Also, I can't figure out how to get this to work.
Do I rename the Mach4GUI?  Or rename my profile?
Chad Byrd
« Reply #3 on: August 13, 2021, 09:59:02 AM »
create a shortcut
« Reply #4 on: August 13, 2021, 10:02:31 AM »
Still Lost.
I cannot use "/"  while renaming anything.
Chad Byrd
« Reply #5 on: August 13, 2021, 10:05:47 AM »
After creating a new shortcut(named whatever you want,(eg.'Open M4 in editor') right click and select properties.  It is in the 'Target' property that you put the aforementioned string.
« Reply #6 on: August 13, 2021, 10:28:15 AM »
I must have really screwed something up.  It still won't open and tells me that I have something wrong with the PLC Script.
C:\Mach4Industrial\Mach4GUI.exe /p OD_Grinder/e
Here is the path that I'm using.
Chad Byrd
« Reply #7 on: August 13, 2021, 10:29:33 AM »
Ok.  So I made a copy of the Mach4GUI and just put the property of "/e" in the line and it allowed me to open into the screen editor.
Chad Byrd
« Reply #8 on: August 13, 2021, 10:31:46 AM »
Thanks RT!
That'll do it for me.  Got it taken care of!
Chad Byrd
