Hello Guest it is November 13, 2026, 09:46:23 AM
Author Topic: Trouble homing master/slave axis and other possible issues. Need help.  (Read 22734 times)
Problem:  Unable to get master (y) & slave (a) axis to home together.  The slave will only run with the master, never separate.  So I am unable to reliably square my gantry when homing the machine.
While trying a few things in the "edit button script" I noticed some things that didn't match up to what I had seen in other posts.
DoButton( 24 ) - Controlled Z axis
DoButton( 23 ) - Controlled Y axis
DoButton( 22 ) - Controlled X axis
DoButton( 25 ) - Did nothing, however I had to physically trip the homing switch on the A axis <or> hit reset to be able to REF ALL again
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
I've seen other forum posts where the DoButton codes were as follows...
24 - Z
23 - X
22 - Y
25 - A
Everything appears to be connected properly and my ports/pins are set correctly.  Home w/master axis is unchecked in general config tab.
Software: Mach3
Motion Controller: Digital Dream UC300
https://www.nvcnc.net/uc300.html
Any help is appreciated.
Modify message
  •  9,377 9,377
Re: Trouble homing master/slave axis and other possible issues. Need help.
« Reply #1 on: August 10, 2021, 09:59:16 PM »
Due to their license violation this forum does not support Novusun products. You need to contact the manufacturer / supplier of your Digital Dream controller and seek their assistance with any Mach3 settings isues you may have.
