Hello Guest it is November 13, 2026, 12:23:50 PM
Author Topic: Drop down menus under Config  (Read 25171 times)
« on: August 06, 2021, 01:27:58 AM »
Hey everybody,
I'm having a rather odd problem. I need to do the Motor Tuning but when I click on the Config drop down and then on Motor Tuning, there is no response. I can access all other menu items but not motor tuning. Any ideas?
  •  9,377 9,377
Re: Drop down menus under Config
« Reply #1 on: August 06, 2021, 01:59:50 AM »
This problem crops up every now and again, I think the only solution is to uninstall then reinstall Mach3.
Make a secure backup of your existing Mach3 folder first so you can copy over <your profile> .xml file and any special screens or macros you use from the backup to the new install.
« Reply #2 on: August 06, 2021, 06:50:30 AM »
Thanks Tweakie.
That was my go to action if no-one came up with a better solution. First job in the morning   :)
« Reply #3 on: August 07, 2021, 01:53:35 AM »
Thanks again, Tweakie. Problem solved. Now for all the other problems  ;D
  •  9,377 9,377
« Reply #4 on: August 07, 2021, 04:35:16 AM »
 :D :D :D
