Hello
Guest
it is
November 13, 2026, 09:51:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Drop down menus under Config
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Drop down menus under Config (Read 25166 times)
Dougsshed
37
on:
August 06, 2021, 01:27:58 AM »
Hey everybody,
I'm having a rather odd problem. I need to do the Motor Tuning but when I click on the Config drop down and then on Motor Tuning, there is no response. I can access all other menu items but not motor tuning. Any ideas?
Logged
Tweakie.CNC
9,377
Super Kitty
Re: Drop down menus under Config
Reply #1 on:
August 06, 2021, 01:59:50 AM »
This problem crops up every now and again, I think the only solution is to uninstall then reinstall Mach3.
Make a secure backup of your existing Mach3 folder first so you can copy over <your profile> .xml file and any special screens or macros you use from the backup to the new install.
Logged
Dougsshed
37
Reply #2 on:
August 06, 2021, 06:50:30 AM »
Thanks Tweakie.
That was my go to action if no-one came up with a better solution. First job in the morning
Logged
Dougsshed
37
Reply #3 on:
August 07, 2021, 01:53:35 AM »
Thanks again, Tweakie. Problem solved. Now for all the other problems
Logged
Tweakie.CNC
9,377
Super Kitty
Reply #4 on:
August 07, 2021, 04:35:16 AM »
Logged
Print
Pages:
1
Go Up
« previous
next »
