Hello Guest it is October 24, 2026, 01:56:34 PM
Author Topic: Faind Z  (Read 25882 times)
Re: Faind Z
« Reply #20 on: August 01, 2021, 11:52:34 PM »
Does Mach4 work without writing a script?
You can write a button script, a module with lua to work with.
If you use the built in module for probe moves no need to change anything, you only put the settings for your machine.
Re: Faind Z
« Reply #21 on: August 02, 2021, 03:25:20 AM »
There was a video of how to use Touch.
https://www.youtube.com/watch?v=VA49atQNzmg
Mach4 has become convenient because you can measure height etc. with the push of one button! !!
However, the Grond Probe may be a BOB or ESS failure.
I bought USS about 5 years ago, but it was out of order from the beginning.
Re: Faind Z
« Reply #22 on: August 02, 2021, 10:25:48 PM »
Hi Toshio,
As you told me, you posted your question here and on the Warp9Tech forum as well. Here I found a solution to your problem.
First, for input X203, you need to set port 2 and pin 3 for the probe signal.
Second, for input connection, you don't need to add extra electronics components.
« Last Edit: August 02, 2021, 10:30:32 PM by Weerasak »
The CNCRoom.com, the place where Industrial Hobbyists can talk and trade!
www.cncroom.com/forum
Re: Faind Z
« Reply #23 on: August 02, 2021, 11:10:15 PM »
Hello.
Are you Andy?
I saw the email from you.
Removing the resistors and capacitors does not change the result.
that's all.
Please send a replacement to my home as soon as possible.
Re: Faind Z
« Reply #24 on: August 03, 2021, 12:37:44 AM »
Answer Hello Weerasak.
Thank you.
Mach3 is now normal.
However, for Mach4DEMO, Touch Z is not normal.
Does not measure height.
Please look at the photo.
Re: Faind Z
« Reply #25 on: August 03, 2021, 07:45:53 AM »
Correct.
