Hello Guest it is October 24, 2026, 10:06:02 PM
Author Topic: Faind Z  (Read 25921 times)
Re: Faind Z
« Reply #10 on: August 01, 2021, 03:21:31 PM »
I'm using MB3.
Please tell me the solution in this case.
MB3 is the controller? I am not familiar with this one..
Re: Faind Z
« Reply #11 on: August 01, 2021, 04:17:36 PM »
MB3 is BOB.
It is sold at CNC Room in Thailand.
This is an instruction manual.
https://cncroomx.com/wp-content/uploads/downloads/MB3-Owner-Manual-E20R2.pdf
Re: Faind Z
« Reply #12 on: August 01, 2021, 04:25:14 PM »
I am sorry, i can't help you with that. You should ask someone/somewhere who knows about that board (MB3).
Re: Faind Z
« Reply #13 on: August 01, 2021, 04:49:03 PM »
I understand.
I will also ask the place of purchase.
Please look at the photo.
This is the case for Mach3.
It is displayed as GROUND PRO BE.
Please tell me the meaning.
Re: Faind Z
« Reply #14 on: August 01, 2021, 04:54:29 PM »
This usually means that the probe is triggered. Your probe input send to Mach3/4 that probe hit the material when it shouldn't and that why you get the alarm.
Re: Faind Z
« Reply #15 on: August 01, 2021, 04:59:44 PM »
I think MB3 is normal, but is my circuit wrong?
Re: Faind Z
« Reply #16 on: August 01, 2021, 05:05:51 PM »
Where you found that circuit?
I can't say if is wrong or right but first time i see two GND to a sensor and a electrolytic capacitor not connected to +V.
Re: Faind Z
« Reply #17 on: August 01, 2021, 05:08:58 PM »
Resistors and ceramic capacitors prevent chattering.
Even excluding resistors and ceramic capacitors, it still says "GROUND PROBE".
Re: Faind Z
« Reply #18 on: August 01, 2021, 05:15:39 PM »
Yes, i understand why are there but i don't see where the + at the capacitor to work for that. I am not an electronic so don't listen to me :).
I hope some one else know more about that and help you.
I am almost sure that MACH4 is not your problem here.
Re: Faind Z
« Reply #19 on: August 01, 2021, 05:22:53 PM »
I am new to Mach4.
In the case of Mach3, I wrote a script to the button of Aou To Zero and it worked. Does Mach4 work without writing a script?
