Hello Guest it is October 24, 2026, 04:32:23 PM
Author Topic: Device error triggered appears randomly  (Read 25409 times)
« on: July 30, 2021, 06:38:27 PM »
Hi everyone,
Device error triggered appears randomly when i'm machining and it stop the machine, it can appears 10 min after i start machining or after 2 or 3 hours
I changed my mach3 version from the 3.043.066 the the 3.043.062 and still have this problem, i'm using a dedicated computer with windows xp and nothing else than mach3 on it, not even internet.
Here is a video of the problem, you can see that the spindle is still turning very slowly, so maybe there is a data leak ? I'll try to change the usb cable on monday but mine is a good quality one so i don't expect much results
https://1drv.ms/v/s!AhY1EpZq7TgH2i4KTnj0u6dI_iKO?e=fcopWt
Any ideas are welcome ! i'm totally lost at this moment and i'll be happy to finish a project that requires 6 hours of machining ... :(
Re: Device error triggered appears randomly
« Reply #1 on: April 20, 2023, 09:54:32 AM »
Hello, I have a similar problem. Message "Error triggered" close my Mach3
Screen in attachment. Could you help me solve the problem? Regards.
« Reply #2 on: April 20, 2023, 10:41:52 AM »
IDK if this will help you but for my problem i used a different AC outlet for every components, 1 for the computer, 1 for the spindle, to minimize interference, also used a pci usb and another USB cable
« Reply #3 on: April 24, 2023, 03:32:48 PM »
thanks for the answer
I bought a new cable but not help
error didn't change
all the time it close my Mach3
« Reply #4 on: April 24, 2023, 04:56:27 PM »
You can also try another version of the ncusbpod.dll, it could help, otherwise try another version of mach3, some have bugs, good luck ..
