Hello Guest it is November 13, 2026, 02:56:15 PM
Author Topic: Mach3 reads the home switches but it doesn't stop  (Read 23190 times)
« on: July 24, 2021, 01:24:45 PM »
Hi all, So I just assembled a new machine with a motion board WIXHC MK4-V (XYZA). So far all axes are moving. But when it comes to homing the machine is not capable to stop. It goes true the limits and it hits the motors boundaries. It recognizes that the switch was activated I can see in the Diagnostics window the led indicator. I'm also having a plug-in for the motion board installed.
What could be the reason of not stopping? The E-stop right now on the board is just connected to 0V as I'm not having still a physical emergency button. Ah yes, I have just home home switches, not limit switches.
Re: Mach3 reads the home switches but it doesn't stop
« Reply #1 on: July 29, 2021, 02:12:29 PM »
have you set up the homing and soft limits
Offline Filou
  •  59 59
« Reply #2 on: October 04, 2021, 01:00:36 PM »
I'm not familiar with your HW, but why do you assign all four pins, 0,1,2 and 5 to DIFFERENT ports ? Naively, I would expect to route these signals trough one or maybe two two different ports but certainly not five.
