Hello Guest it is October 24, 2026, 02:34:23 PM
Author Topic: API For Axis Homed  (Read 7187 times)
API For Axis Homed
« on: July 21, 2021, 09:36:47 AM »
Is there an API that when called would indicate that a particular axis is homed ?
I did some testing and the "homed LEDs" on the standard Mach screenset do not behave as I would like. I would expect them to go red again if an estop condition occurred since that is not a controlled stop and any home position cannot be known/guaranteed.
I am trying to add some safety scripting to force me to home when I try to do certain operations(e.g. cycle start, probing, ...) and an axis is not homed.
Re: API For Axis Homed
« Reply #1 on: July 21, 2021, 02:56:56 PM »
There is an option in the config to de-reference axes when e-stop is pressed
Offline Bill_O
  •  615 615
« Reply #2 on: July 21, 2021, 04:27:58 PM »
I think this is what you are looking for.
LUA Syntax:
homed, rc= mc.mcAxisIsHomed(
      number mInst,
      number axisId)
« Reply #3 on: July 21, 2021, 05:52:38 PM »
Thanks for the code snippet!
One last question on this topic... Does the RED STOP button also deference the Axes ?
« Reply #4 on: July 22, 2021, 03:49:41 AM »
It doesn't, but you can use the following. I've also attached a picture showing the deref on estop option
Code: [Select]
rc = mc.mcAxisDeref(
                    number mInst,
                    number axisId)
or
Code: [Select]
rc = mc.mcAxisDerefAll(
                       number mInst)
