Hello
Guest
it is
October 25, 2026, 07:53:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
pmc -parallel line how to do?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pmc -parallel line how to do? (Read 5336 times)
KatzYaakov
600
on:
June 15, 2021, 05:53:55 AM »
hi
i start test use pmc and its quit help in some event handler using
but i try do multiply coil in parallels ,but cant find how do it
please if some one can explain
smurph
1,575
"That there... that's an RV."
Re: pmc -parallel line how to do?
Reply #1 on:
June 18, 2021, 01:52:52 AM »
You can place your cursor to the left, right, or underneath most object to insert other objects. So to do a parallel op, place the cursor under the existing coil and insert another coil.
Steve
Print
Pages:
1
Go Up
« previous
next »
