Hello Guest it is October 25, 2026, 07:54:39 AM
Author Topic: pmc -parallel line how to do?  (Read 5338 times)
« on: June 15, 2021, 05:53:55 AM »
hi
i start test use pmc and its  quit help in some event handler using
but i try do multiply coil in parallels ,but cant find how do it
please if some one can explain
Offline smurph
  •  1,575 1,575
Re: pmc -parallel line how to do?
« Reply #1 on: June 18, 2021, 01:52:52 AM »
You can place your cursor to the left, right, or underneath most object to insert other objects.  So to do a parallel op, place the cursor under the existing coil and insert another coil.
Steve
