Hello Guest it is November 18, 2026, 08:01:44 AM
Author Topic: Mach3 macro homing  (Read 63831 times)
Re: Mach3 macro homing
« Reply #10 on: June 25, 2021, 12:41:59 AM »
I am using a ethernet smooth stepper from warp9.
Regards Morten
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: June 25, 2021, 09:21:03 PM »
When you are trying the macro do you have single block enabled?
« Reply #12 on: June 26, 2021, 12:04:35 AM »
No single step enabled, just runs the macro. Mach must have a stop function after doing a homing sequence?
Offline TPS
  •  2,627 2,627
« Reply #13 on: June 26, 2021, 02:09:16 AM »
here is a piece of code that i am using on one of my machines:
Code: [Select]
Sub Main()
' TPS 26.06.2021
' do a referece
' new version with OEM Led's
'quit if file is loaded
If IsLoading() Then
    GoTo Ende
End If
Message ("automatic reference started")
'reference Z
Message ("Z-axis reference")
DoOemButton(1024) 'Ref Z
Sleep(500)
While GetOemLed(809) = true
    Sleep(200)
    If GetOemLed(800) Then
        Sleep(500)
        Message"error while referencing"
        End
    End If
Wend
Sleep(500) 'wait
Message (" ") 'clear status line
Sleep(200) 'wait
Exit Sub
Ende:
End Sub
it is for z-axis because i have no c-axis.
it runs from VB-Editor and also due g-code call.
in your case it would be oembutton(1027) and oemled(812) for c-axis.
  •  2,785 2,785
« Reply #14 on: June 26, 2021, 11:56:11 AM »
If you run a normal .tap file with the following lines what happens
O0001 (TEST C HOMING)
G91 G28 C0
M30
« Reply #15 on: June 28, 2021, 12:25:47 PM »
Thanks for all the answers.
I must have done something wrong when testing G91 G28 C0, because I can make that work, but it uses Mach3 homing setting and not the more precise smoothstepper homing - backing off the sensor at another speed.
When playing with the above, I found out that it homed at another speed and did not back of the sensor, and then it hit me, could it be a smoothstepper homing bug? Yes it is, if I disable the smoothstepper homing settings it works as expected.
I will contact warp9 and tell them about the bug.
Once again, thanks for all your solutions and help, this is a fantastic place.
Regards Morten.
« Reply #16 on: July 01, 2021, 02:38:39 PM »
Hi again,
It is not a ESS bug, but a mach3 thing - Andrew from warp9 explained to me...
But the G91 G28 C0 does not work - it just moves the C-axis to machine C0 position, but when the clutch for the caxis have been disengaged for normal turning it does not know where it is, I did not see this when playing with it the last time...
I have asked warp9 if they have a suggestion, and if possible to use ESS for homing only some axis and other use mach3 homing.
I am still open to any input you might have.
Regards Morten
Offline TPS
  •  2,627 2,627
« Reply #17 on: July 02, 2021, 02:37:24 AM »
have you tryed to use G28.1 insteed of G28
G28 is a Return to home Position
G28.1 is a Reference Axis
« Reply #18 on: July 02, 2021, 08:20:40 AM »
Tried G28.1 and it works from the MDI, but if macro called from gcode, the smoothstepper takes over the homing and wait for cycle start :(
Regards Morten
Offline TPS
  •  2,627 2,627
« Reply #19 on: July 02, 2021, 12:10:01 PM »
this with the cycle start must be smoothstepper specific.
i use Buttons 22-24 on my machines (CSLAB controller) within macros and do not have to press cycle start.
