Hello Guest it is November 23, 2026, 03:05:56 AM
Author Topic: Mach3 macro homing  (Read 63884 times)
Mach3 macro homing
« on: June 10, 2021, 08:40:45 AM »
I have a lathe with a C-axis that is engaged with an electrical clutch to the spindle that works very well, I have a macro that enables the clutch and it works fine, then I have an other macro that also homes the C-axis that also works fine, the use of this is when I do more operations that have normal turning in between c-axis operations and these operations needs to be angled to each other. Every time a program calls my macro with homing and it's done I have to press cycle start to continue? guess it has something to do with the homing. My macros are like this:
with auto homing:
While IsMoving()
Wend
DoSpinStop()
While GetOEMled(1000)
Wend
If getoemled(164) Or getoemled(165) Then
Else
ActivateSignal(OUTPUT4)
Sleep(300)
   If GetOEMLED(845)   Then
      Code "G91 G0 C35"
      While isMoving()
      Wend
   End If
Code "G90"
DoOEMButton(1027)
While ismoving()
Wend
End If
without homing:
While IsMoving()
Wend
DoSpinStop()
Wend
Else
Sleep(300)
End If
Hope you can help me out, or give me a clue what to look for.
Regards Morten.
Offline TPS
  •  2,627 2,627
Re: Mach3 macro homing
« Reply #1 on: June 10, 2021, 10:21:42 AM »
you can try to do a
RefCombination(32)
insteed of
DoOEMButton(1027)
maybe it helps
« Reply #2 on: June 10, 2021, 11:59:19 AM »
Thanks for the suggestion, I tried changing my macro, but if I run a g-code where it calls that macro it does not home my c-axis, and if I put it in the MDI it homes the c-axis but after that it kind of hangs for like 20 sec. before mach will accept a new command.
regards Morten
Offline TPS
  •  2,627 2,627
« Reply #3 on: June 11, 2021, 12:58:10 AM »
sounds strange. witch Version of Mach3 are you using?
« Reply #4 on: June 11, 2021, 05:43:03 AM »
Yeah it's strange, I use Mach3 version R3.043.062 - the recommended version with my ethernet smoothstepper.
Regards Morten
Offline TPS
  •  2,627 2,627
« Reply #5 on: June 14, 2021, 12:13:53 AM »
sorry, missed your answer.
for the Moment the only idea i have is, that Mach may be corrupted.
i would try to install a fresh copy.
« Reply #6 on: June 22, 2021, 09:56:28 AM »
thanks for your answer, I tried another pc with a fresh mach3 install, same as above.
Guess I have to live with pressing cycle start for now:-)
Regards Morten
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #7 on: June 22, 2021, 08:48:04 PM »
Have you tried using the Standard button call DoButton (27)
or
Code ("G91 G28 C0")
While IsMoving()
  Sleep(25)
Wend
« Reply #8 on: June 24, 2021, 01:35:31 PM »
Thanks for your reply, tried both solutions, the dobutton(27) also waits for cycle start to be pressed if called from a gcode, the other one works if I run it in the editor, but if called from a gcode it just does not home the axis, but does not wait for cycle start.
Regards Morten
Offline TPS
  •  2,627 2,627
« Reply #9 on: June 25, 2021, 12:36:46 AM »
witch Motion Controller are you usining?
