Hello Guest it is October 11, 2026, 10:10:01 PM
Author Topic: Reinstall Windows XP, Mach3V2.48 and now motors wont move  (Read 24215 times)
Re: Reinstall Windows XP, Mach3V2.48 and now motors wont move
« Reply #10 on: October 23, 2007, 04:28:56 PM »
Hello Hood.
 I feel like a foul, but the problem was that I inverted the the step and dir inputs when I reinstall Mach3. Insted of setting 3-2 5-4 7-6 9-8  I put 2-3 4-5 4-7 8-9. I don't know why I end up with that combination. The only problem now Is that I cannot make the motor for axis Y move. The other  three motors run nicely.
« Reply #11 on: October 23, 2007, 05:11:02 PM »
Ha ha weve all done that :D
Just have to check your wiring and settings again, if no movement then check with Parallel port cable removed and a voltmeter on the Y axis pins to see if they are getting the correct voltage.
« Reply #12 on: October 25, 2007, 12:53:33 PM »
Hello Hood.
Checked my wires and reinstall them. Machine, now running nicely.
Thank you very much.
Hugo Carradini
« Reply #13 on: October 25, 2007, 02:28:33 PM »
Excellent news.
