Hello Guest it is September 26, 2026, 12:06:57 AM
Author Topic: Reinstall Windows XP, Mach3V2.48 and now motors wont move  (Read 24067 times)
« on: October 14, 2007, 03:12:35 PM »
Hello Guys.
I finished and had for few days my router table, working nicely. One week ago I decide to dedicate this computer to the machine  so I  Des-install and install again Windows XP and a newer version of Mach3 V2.48. . Since then I have not been able to run my motors any more. I know they engage because I cant make them move and they get slightly warm but no vibration or noise at all. I use another computer with W. XP and an older Mach3 and still the same problem, the motors wont move. Y use G230V drives, PMDX-122 breakboard and Orientals Motors PK296A2A-SG7.2 run by Windows XP and Mach3 V2.48 I fallowed carefully the steps to install in Mach and cant correct the problem so y need help, :-[ urgent help :-[
Thanks in advance
Hugo
Re: Reinstall Windows XP, Mach3V2.48 and now motors wont move
« Reply #1 on: October 14, 2007, 04:07:13 PM »
please post your xml file and maybe someone will find a problem with it.
« Reply #2 on: October 15, 2007, 02:06:09 PM »
Thanks for answering Hood
Stupid question. ¿I go to Mach3 and copy a file that says  xml ? I can copy and post but just want to be sure of what file I have to send.
« Reply #3 on: October 15, 2007, 02:57:52 PM »
What profile do you use for Mach? Do you just start by clicking on the Mach3Mill icon? If yes then look for Mach3Mill.xml, you will have to copy it to another location then rename it to something else, Hugo.xml for example. You can then attach it to a post by using the additional options button. If you dont rename it you wont be able to attach it as someone else in the past will have attached Mach3Mill.xml and the forum will only allow one example of each.
« Reply #4 on: October 16, 2007, 03:43:10 PM »
Hello Hood
When I tried to send the post it gives me these answer "The attachments upload directory is not writable. Your attachment or avatar cannot be saved."
I send the file to my documents, named, and then tried to attach from documents to the post with no success's. ¿What am I doing wrong?
« Reply #5 on: October 16, 2007, 06:01:19 PM »
I think there are a few problems with the forum at the moment. It is being migrated from Artsoft to Mchsupport and there seems to be a few glitches. Send it to me via email and I will have a look tomorrow. I will give you my email address by private message.
« Reply #6 on: October 16, 2007, 06:03:19 PM »
Have sent you an email
« Reply #7 on: October 19, 2007, 01:01:18 PM »
Hello Hood.
Excuse me for not answering rigth away but my wife got plans for me that made me 100% occupied. ¿Can you please send again the email?
« Reply #8 on: October 22, 2007, 10:02:02 AM »
Hello Hood. I all ready send the file to your e-mail.
« Reply #9 on: October 23, 2007, 02:40:19 PM »
Had a look at the xml and dont see anything wrong, can you check with a voltmeter that you are getting OV and 5V on the direction pins when you jog one way then the other. Just disconnect the cable from the breakout so you have easy access to the pins for testing.
