Hello Guest it is October 21, 2026, 08:48:14 PM
Author Topic: Threading with mach3  (Read 16704 times)
« on: April 29, 2021, 03:38:26 PM »
Hello everyone,
I have converted my mini lathe MX-210V to cnc lathe, but now i want to cut threads.
Can i use the sensor which comes with the lathe for reading the rpms or must be different sensor.
I'm using RNR Motion Card
Thanks!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Threading with mach3
« Reply #1 on: April 29, 2021, 04:06:14 PM »
As long as you get a clean pulse into the board and the board can do index threading you are good, optical switches are better.
« Reply #2 on: May 02, 2021, 02:31:53 AM »
How many pulses per rev does it generate?  M3 needs just 1 ppr.   Opto are good, Hall Effect also good,  many addon tachos use Hall sensors.
