Hello
Guest
it is
November 22, 2026, 11:13:21 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Threading with mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Threading with mach3 (Read 16951 times)
bujidur
1
on:
April 29, 2021, 03:38:26 PM »
Hello everyone,
I have converted my mini lathe MX-210V to cnc lathe, but now i want to cut threads.
Can i use the sensor which comes with the lathe for reading the rpms or must be different sensor.
I'm using RNR Motion Card
Thanks!
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Threading with mach3
Reply #1 on:
April 29, 2021, 04:06:14 PM »
As long as you get a clean pulse into the board and the board can do index threading you are good, optical switches are better.
Logged
JohnHaine
975
Reply #2 on:
May 02, 2021, 02:31:53 AM »
How many pulses per rev does it generate? M3 needs just 1 ppr. Opto are good, Hall Effect also good, many addon tachos use Hall sensors.
Logged
Print
Pages:
1
Go Up
« previous
next »
