Hello Guest it is November 23, 2026, 05:08:41 AM
Author Topic: Mach3 Uc300  (Read 29028 times)
Mach3 Uc300
« on: April 26, 2021, 04:51:19 PM »
Hello all,
Im new to the world of CNC, and find the learning curve rather steep.
I have spent the whole day trying to get the home/limit switches and Estop working on my setup.
My setup is windows 10 running mach3, using a digital dream uc300 controller via USB.
I think it’s all configured right but I can’t get the switches to switch.
In the diagnostics windows they are on or off, ticking the active low in ports and pins makes it go off but no switching.
Anyone have any ideas why?
Its almost like its not seeing the inputs.
Any input is greatly appreciated.
  •  9,378 9,378
Re: Mach3 Uc300
« Reply #1 on: April 27, 2021, 12:06:43 AM »
Hi dly.xover,
You need to contact the suppliers of your controller for their assistance in setting everything up correctly.
It is unfortunate but due to Mach3 License violation this forum does not support Digital Dream products.
This thread refers; https://www.machsupport.com/forum/index.php?topic=24331.0
Re: Mach3 Uc300
« Reply #2 on: April 27, 2021, 01:58:51 AM »
Thanks for the reply Tweakie.
I was unaware of this issue, I have a mach licence.
what controller would you recommend instead of the uc300
  •  9,378 9,378
Re: Mach3 Uc300
« Reply #3 on: April 27, 2021, 02:05:48 AM »
Any of the US or EU manufactured controllers are suitable and well supported by their manufacturers & this forum.
If it's any help, one that I use with Mach3 is the Warp9 ESS - https://warp9td.com/
« Last Edit: April 27, 2021, 02:10:51 AM by Tweakie.CNC »
Re: Mach3 Uc300
« Reply #4 on: May 02, 2021, 06:03:27 PM »
Hi Tweakie
I'm about to order the controller you suggested, would you go for the USB or Ethernet?
I've had more issues trying to get the machine running, it seems the UC300 S*$t the bed on the first test cut and has been 'unavailable' since.
thanks
Re: Mach3 Uc300
« Reply #5 on: May 02, 2021, 11:54:39 PM »
Warp9TD have not manufactured USB connected motion boards for some years, the only current manufactured boards are
Ethernet connected, which is good news because Ethernet connection results in lower latency and much greater noise immunity.
  •  9,378 9,378
Re: Mach3 Uc300
« Reply #6 on: May 03, 2021, 12:02:05 AM »
Hi dly.xover,
The Ethernet version.
(The USB version is really only offered for sale by Warp9 as a 'replacement part' as all future development, bug fixes, etc., for the USB product have now ceased).
Re: Mach3 Uc300
« Reply #7 on: May 03, 2021, 06:40:43 AM »
what do you use for adapter cable to go from the 26pin header cables?
  •  9,378 9,378
Re: Mach3 Uc300
« Reply #8 on: May 03, 2021, 08:53:23 AM »
Various cables are available from the Warp9 website;  https://warp9td.com/index.php/order#Ordering
