Hello Guest it is November 13, 2026, 03:46:48 PM
Author Topic: Mach 3 rapid clearance question  (Read 16161 times)
« on: March 31, 2021, 12:08:59 PM »
Wondering why my rapid clearance dose not always work . It is correct in the G code Z of 1.00 and it always works when i dry run with torch turned off but with torch turned on it drags on the sheet even tho the g code is correct . Any ideas ?
Offline TPS
  •  2,627 2,627
Re: Mach 3 rapid clearance question
« Reply #1 on: April 03, 2021, 10:37:04 AM »
maybe THC is enabled?
