Hello
Guest
it is
November 27, 2026, 09:37:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach 3 rapid clearance question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 rapid clearance question (Read 16231 times)
prcfab
1
on:
March 31, 2021, 12:08:59 PM »
Wondering why my rapid clearance dose not always work . It is correct in the G code Z of 1.00 and it always works when i dry run with torch turned off but with torch turned on it drags on the sheet even tho the g code is correct . Any ideas ?
Logged
TPS
2,627
Re: Mach 3 rapid clearance question
Reply #1 on:
April 03, 2021, 10:37:04 AM »
maybe THC is enabled?
Logged
Print
Pages:
1
Go Up
« previous
next »
