Hello
Guest
it is
October 25, 2026, 06:04:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Milling machine wirth servos
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
Go Down
Author
Topic: Milling machine wirth servos (Read 152403 times)
DennisF
388
Re: Milling machine wirth servos
Reply #50 on:
October 24, 2007, 04:37:49 PM »
The drives have some kind of fault and have shut down from what servo dynamics says so i have to figure out what that is and get it fixed first what ever that is.
Dennis
DennisF
388
Reply #51 on:
October 25, 2007, 06:10:28 PM »
Would anyone know where i can get a used or new part other then from the manufacture i just need the bottom half of my spindle motor pulley for my lagunomatic 250.
Dennis
Chip
2,055
Gainesville Florida USA
Reply #52 on:
October 29, 2007, 11:47:12 PM »
Hi, Dennis
Have some info on your SD1525-10 servo boards, Lost your Phone # in a pile of paper's, what a Mess.
Thanks, Chip
DennisF
388
Reply #53 on:
October 31, 2007, 09:53:47 AM »
Chip
# 650-359-0406 trying to figure out how to fix the fault on the drives.
Dennis
DennisF
388
Reply #54 on:
October 31, 2007, 04:10:57 PM »
Well sat down today and figured out the current supply problem to the drives and it turned out badly the drives have a secondary power supply this provides the +15 & -15 volt's to the drives it's bad and may have damaged the drive's talking to servo dynamic drive corp they say to repair just one drive is $900.00 so i am not going to even play with them everything is coming out and i'll start from scratch.
In looking at the only other drives i have found so far that can handle the power of my servos which is 120 volt dc is the drives from AU do they have a US dealer?
Dennis
Dennis
Carnoustie, Scotland
Reply #55 on:
October 31, 2007, 05:01:48 PM »
There are 2 drives fromm Ozz, the ones that can handle 120+Volts must be the Rutex ones. Heres the US site
http://www.rutex.com/us
DennisF
388
Reply #56 on:
November 01, 2007, 10:16:52 AM »
Thanks for the info on rutex what other parts would i need in addition to these drives power supply pixes and an interface card?trying to figure what the cost for everything to get it to work correctly dose rutex have support the drives are pretty good price baldor and servo dynamics also make drives for these motor's but they are way more money.
Dennis
Reply #57 on:
November 01, 2007, 02:38:50 PM »
You dont need pixies as these drives take step and direction inputs. You will need to build a power supply and you will need a breakout board. You may have all the nesecarry components in your cabinet for your power supply already so have a look and see before you discard everything.
DennisF
388
Reply #58 on:
November 02, 2007, 10:07:35 AM »
well for starters it's good news that all i need to buy is the rutex drive that would help in cost i have in the cabinet a power supply putting out 75- 100 Volts DC there are other taps on the transformer that i have not checked i don't plan to chuck the power supply just all the other electronics would any of the break out boards work on the rutex drives or would it be a special board just for those drives.
Dennis
DennisF
388
Reply #59 on:
November 02, 2007, 10:26:43 AM »
Also how is the feed back from the servos handled.
Dennis
Print
Pages:
1
2
3
4
5
6
7
8
9
10
Go Up
« previous
next »
