Hello Guest it is November 23, 2026, 05:08:48 AM
Author Topic: Milling machine wirth servos  (Read 155398 times)
Re: Milling machine wirth servos
« Reply #20 on: October 13, 2007, 05:24:32 PM »
 on the motor it says transducer 10 would that mean its a 10 V motor the model # is Baldor Big mho MTE 4070 fl 5b, i tried to look it up on the web but i couldn't find any info on it.
Dennis
« Reply #21 on: October 13, 2007, 06:41:50 PM »
one for each axis, but make sure first that your drives are definately not capable of step/dir. Do you know the make/type of drives you have?
« Reply #22 on: October 13, 2007, 07:46:08 PM »
the drives are servo dynamics corp.
Dennis
« Reply #23 on: October 13, 2007, 08:02:22 PM »
you know the model numbers?
« Reply #24 on: October 13, 2007, 08:35:09 PM »
Yes,model # SD1525-10 15 amp i take it that the last number is the voltage 10.
Dennis
« Reply #25 on: October 13, 2007, 11:46:26 PM »
hood i have been trying to find info on this drive but no luck so far even checked the company web site again no info and if hgte drive will accept step & direction
Dennis
« Reply #26 on: October 14, 2007, 01:46:42 AM »
The 10 15 may well be 10Amp continuous 15Amp peak.
 Will look and see if I can find any info
« Reply #27 on: October 14, 2007, 02:19:34 AM »
Not found specifics yet but for a MTE-4070 it say rated 100V  6amp contin 24Amp peak
As for the drives again no specifics but its looking like they are analogue.
Do you have any pics of the drives?
« Reply #28 on: October 14, 2007, 03:07:51 AM »
OK been doing a bit of reading and almost definite that these are analogue drives, you will need pixies.
Heres a thread I found at Skykos site. http://www.skyko.com/cgi-bin/yabb2/YaBB.pl?num=1170520068
« Reply #29 on: October 14, 2007, 01:44:37 PM »
 I was hoping i would not have to change out the drive that the way it goes, why the pixes are they better then the gecko's, can you explain the difference between a step and direction drive and analogue drive i thought there was way to many connections on tese drives to work with Mach.
Dennis
