Hello Guest it is November 26, 2026, 04:52:27 AM
Author Topic: ShuttlePro Losing Setup  (Read 9267 times)
« on: March 25, 2021, 12:58:03 PM »
My ShuttlePro is losing setup information. I use it to jog the x, y, and z. I use the inner wheel to jog in small increments (0.001"). I set the increments using the Incremental Jog Step on the Jogging tab. This along with the key mapping sometimes is not saved between closing and opening Mach. Unfortunately, I first noticed this when trying to check the z-zero position. I had the z- jogged close to the workpiece and was going to gauge the setting by sliding a piece of paper back and forth under the bit will stepping down in 0.001" increments. However, the increment was reset to 1". Needless to say, my bit exploded when it took that 1" step into the workpiece.
I assume this is a bug???
GOOMBA
Re: ShuttlePro Losing Setup
« Reply #1 on: March 29, 2021, 10:10:52 AM »
What build of MACH are you running?
« Reply #2 on: March 29, 2021, 10:58:09 AM »
Mach4 Build 4612 and ESS 272.
Offline smurph
  •  1,575 1,575
« Reply #3 on: March 29, 2021, 12:16:16 PM »
Yeah, this caught me too.  At first, I just thought it was a problem with my profile.  But I was able to reproduce losing the configuration.  It is fixed it in build 4700.
Steve
« Reply #4 on: March 29, 2021, 02:46:58 PM »
Fantastic! Thanks for the info.
« Reply #5 on: March 29, 2021, 08:15:38 PM »
Is build 4700 available? I only see 4612.
Offline smurph
  •  1,575 1,575
« Reply #6 on: March 30, 2021, 12:03:07 PM »
