Hello
Guest
it is
November 19, 2026, 04:32:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
G codes
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G codes (Read 20674 times)
Jamwelds
2
G codes
on:
March 06, 2021, 11:28:07 PM »
I cannot get g code to load from sheetcam. Files loaded fine until I restarted Mach3, then me jog speed was reduced by approximately 60%, and codes would no longer load.
Logged
TPS
2,627
Re: G codes
Reply #1 on:
March 07, 2021, 02:11:50 AM »
post your g-code and we will see
Logged
Jamwelds
2
Re: G codes
Reply #2 on:
March 07, 2021, 11:38:17 AM »
N0010 File Name: Acadia Column Base Plat 16 in 2 .tap
N0020 Post Processor: Mach3 THC With scriber (Edited)
N0030 Date 3/6/2021
N0040 G20 Units: Inches
N0050 F1
N0060 G53 G90 G40
NOO70 Part: Acadia Column Base Plate 16in 2
NOO80 G00 XO.0000 Y0.0000
N0090 M04 M30
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: G codes
Reply #3 on:
March 07, 2021, 08:59:48 PM »
That code has never run on Mach3 or any other system. The format is all wrong :-
- No brackets
- No brackets
N0030 Date 3/6/2021
- No brackets
- No brackets after G20
N0050 F1
N0060 G53 G90 G40
- No brackets and 'OO' instead of '00'
- 'OO' instead of '00' and 'XO.0000'
N0090 M04 M30
Logged
Print
Pages:
1
Go Up
« previous
next »
