Hello Guest it is October 25, 2026, 12:48:45 AM
Author Topic: Prevent Cycle Timer from zeroing?  (Read 9283 times)
« on: March 04, 2021, 05:12:06 PM »
Hi.
I have a MACH4 question.
As the title says, I would like to stop cycle time when the program ends, but without resetting it to zeroes, as it does every time at the moment. Is it at all possible? I have been trying editing G-Codes for this, but no luck so far. Thanks for any suggestions...
Re: Prevent Cycle Timer from zeroing?
« Reply #1 on: March 05, 2021, 01:42:59 AM »
I'd like to know too.
« Reply #2 on: March 05, 2021, 04:10:06 AM »
What version of Mach are you using? Looking at the change log there were some recent changes to how this works..
Code: [Select]
4564 - 4570
Core: Change run timer characteristics to:
      1. clear upon reset
  2. clear upon file load.
  3. clear upon rewind/run (M99)
  4. clear upon cycle start after rewind.
  5. clear upon cycle start in MDI.
« Reply #3 on: March 05, 2021, 09:25:48 AM »
Thanks for support. I am overdue for update, but currently using 4.2.0 4517
« Reply #4 on: March 05, 2021, 09:28:57 AM »
Code: [Select]
4564 - 4570
      1. clear upon reset
So where should I set one of the characteristics, please? It seems as it would do the job... Is it in screen editing under operator?
Offline jbuehn
  •  101 101
« Reply #5 on: March 05, 2021, 11:11:42 AM »
I don't believe you need to set anything. That list is just telling you each action that will clear the run timer.
« Reply #6 on: March 05, 2021, 11:37:01 AM »
Great news.  So I hope after updating the version the cycle timer will stop zeroing itself after the job finishes. Unless something is wrong with my settings and I don't know about it. Thanks a lot for your help.
