Hello Guest it is November 22, 2026, 07:49:56 AM
Author Topic: Mach3 intervals going 3x as far  (Read 8537 times)
« on: February 12, 2021, 09:05:17 AM »
Hey all, loving the community. I need help with what I hope is a simple solution. My machine is going 3x as far as my user interface is saying in the mach3 program. I would try to troubleshoot myself but I am very new to all this and don't want to screw something up. What would be the reason the machine is going 3x as far as the user interface is saying? For example, the machine moves 3 inches but the Mach3 user interface says it moved 1 inch. and its the same for x, y and z axis.
Thank you!
Ty
Offline TPS
  •  2,627 2,627
Re: Mach3 intervals going 3x as far
« Reply #1 on: February 12, 2021, 10:19:19 AM »
Config -> Motor Tuning -> Step's per for each axis
https://www.machsupport.com/wp-content/uploads/2013/02/Mach3Mill_Install_Config.pdf
chapter 5.5 would be from interest
however the hole Manual might be interesting.
« Last Edit: February 12, 2021, 10:22:36 AM by TPS »
