Hello Guest it is November 17, 2026, 11:30:34 AM
Author Topic: zero setting changes after running program  (Read 19182 times)
Offline R A
  •  10 10
« on: February 06, 2021, 04:54:18 AM »
My cnc mill works under win xp. I am using mach3 the latest version. I want to run a program on my mill several times in succession. The problem is that I have to set the zero setting every time again.
When the program is done the spindle goes to the zero position, but then it changes the coordinates of X, Y and Z. What is the problem here.
Offline TPS
  •  2,627 2,627
Re: zero setting changes after running program
« Reply #1 on: February 06, 2021, 07:12:42 AM »
are only the displayed values on Screen not Zero, or is the machine physicaly not at Zero?
Offline R A
  •  10 10
« Reply #2 on: February 07, 2021, 02:34:38 AM »
The machine is physically at zero except for the Z axis. When I pause and stop the program the coordinates don't change.
Offline R A
  •  10 10
« Reply #3 on: February 07, 2021, 03:02:48 AM »
Thanks for the reply.
I mean pause and stop on the way back to zero after ending the program
Offline TPS
  •  2,627 2,627
« Reply #4 on: February 07, 2021, 05:15:46 AM »
have you selected in Config -> General Config -> Persistent Offsets and Persistent DROs ?
Offline R A
  •  10 10
« Reply #5 on: February 27, 2021, 02:09:16 AM »
Hey
Thank you already for the answer. Yes the Persistent Offsets and Persistent DROs are selected. Things have been getting worse lately. I could pause the program and then manually go to zero, this no longer works because the machine coordinates are now also changing. It makes me desperate
Offline TPS
  •  2,627 2,627
« Reply #6 on: February 27, 2021, 08:42:22 AM »
i would not run Ver .066
try a earlier Version
Here's the link: https://warp9td.com/index.php/sw/software-mach#MachThree
Offline R A
  •  10 10
« Reply #7 on: February 27, 2021, 09:42:27 AM »
Is the ESS plugin for using an ethernet connection?
My controller for the milling machine only works with parallel port. I have a 6040Z-S80 cnc milling machine.
Offline TPS
  •  2,627 2,627
« Reply #8 on: February 27, 2021, 09:45:32 AM »
this: https://warp9td.com/files/Software/Mach3/Mach3Version3.043_2018.exe
will also work with parallel post. make a backup of your existing Mach3 Folder.
Offline R A
  •  10 10
« Reply #9 on: February 27, 2021, 09:47:11 AM »
I am running v.R3.043.066
