Hello Guest it is November 13, 2026, 09:50:31 AM
Author Topic: Home/limits on same switch setup help.  (Read 8658 times)
« on: January 25, 2021, 06:29:02 AM »
Been away from things for a while and can't get this to work.  I have 3 single switches at the positive extents of XYZ travel and want to use them as both home & limits along with soft limits.
I should be able to start Mach3, press Reset, press "Ref all home" and each axis moves until it bounces off its switch, right?  I've missed something silly in the setup somewhere.  Can one of you Gurus take a look at my .xml please?
edit: Oh yeah, all switches are NC and wired in series.
« Last Edit: January 25, 2021, 06:35:07 AM by DICKEYBIRD »
Milton from Tennessee ya'll.
Offline TPS
  •  2,627 2,627
Re: Home/limits on same switch setup help.
« Reply #1 on: January 25, 2021, 08:41:49 AM »
you have to set the Enabled for each Input in Config->Ports&Pins-Input signals
« Reply #2 on: January 25, 2021, 09:19:17 AM »
Ouch! (Dope slapping myself) thanks! :-[
« Reply #3 on: January 25, 2021, 12:24:46 PM »
Thanks TPS, it all works perfectly now. :)
