Hello Guest it is September 20, 2026, 02:52:56 PM
Author Topic: Mach 4 wont recognise UC100 controller  (Read 39544 times)
« on: January 20, 2021, 12:40:06 PM »
I have run my lathe happily  on Mach 3 with the CNCdrive controller http://cncdrive.com/UC100.html
There are some functionality problems with  spindle pulleys and threading , and I was advised that  Mach 4  would overcome these, which is what i am wanting to test .
I have installed Mach 4  , then downloaded the plugin for the UC100  from the above page . I tried both the auto install, and the manual install routes but Mach 4  is not seeing a plugin  for UC100 so I cannot select and configure it .
Can you guide me on how to achieve a working state with this combination.??
Alternatively  can you guide me to a reasonably priced motion controller which is known to work with Mach 4.
John
Re: Mach 4 wont recognise UC100 controller
« Reply #1 on: January 20, 2021, 10:42:17 PM »
there are a number of Mach4 users whom have a UC100 so it definitely does work. The UC100 is a single port equivalent, that
is 17 inputs and outputs, which is very restrictive.
A UC400 and PMDX-424 both have 34 IOs' an Ethernet SmoothStepper has 51 IOs, a 57CNC has 57 IOs, a UC300 has 85 IOs.
Not sure exactly how many a CSMIO and a Hicon have, but plenty.
As you noted all the UCnnn series are made by CNCDrive, the owners and manufacturers of UCCNC. They have a good Mach3 plugin for
all their motion controllers but the Mach4 plugin is weak on realtime supports. Given the competitive nature of the two companies I
don't see CNCDrive expending a lot of effort to improve their Mach4 plugins, when really they'd rather have customers buy UCCNC.
The other manufacturers have expended much more effort on their plugins to ensure maximum facility with Mach4, and include
Warp9TD, PMDX, PoKeys, Vital Systems. CSLabs deserve a mention but their Mach4 plugin lacks polish when not actually buggy. CSLabs
are trying to push their own software and the Mach4 plugin has suffered as a result.
« Reply #2 on: January 21, 2021, 04:52:59 AM »
Thank you for that.
Maybe a more informed view of the prospects than what i have seen so far.  And a perspective on the Mach Vs UCCNC competition ,
I was advised early on that  UCCNC did not really have a decent piece if software for a lathe .
I chose to stick with Mach 3 for early testing mainly because I was familiar with it , but I do see significant failings and there are suggestions that Mach 4 overcomes those , and I being the owner of a UC100 I chose to try that first  .
I have a response on cncdrive forum which suggests the following:-
MAke sure the .net framework 3.5 is installed (enabled in the Windows features on Win 10.)
beyond that  the advice to install the Mach 4 plugin are much as I have already carried out.
I will try that later and report back
« Reply #3 on: January 21, 2021, 03:37:54 PM »
No further forward . Still wont work
« Reply #4 on: January 21, 2021, 04:56:31 PM »
Hi John,
I used the UC100 on my lathe when I converted to Mach4.
I'm sure you have already done all of this but just to make sure.
The uc100 plugin files (.sig and .m4pw) must be in the mach4hobby\plugins directory.
You must enable that plugin by Config->control select Plugins tab and then enable so the green check appears.
Then you can go to the Config->Plugins menu and configure the uc100.
Having said that I abandoned the uc100 because they had not done a thorough testing of the plugin on lathes and there were errors in certain operations.  I went with a pmdx411 and have been happy with its performance but it is limited in the number of inputs as is the uc100.  I still have a version 1 usb smoothstepper that runs a mill under mach3.  Have recently add another mill that runs mach4 with a Pokeys57cnc.  I and others have not been able to get the pokeys to run under usb but runs great over ethernet.  Haven't tested it on a lathe.
HTH
RT
« Reply #5 on: January 22, 2021, 06:36:28 AM »
Hi there .
The files are all there .  CNCdrive suggest it is Artsofts problem not recognising "their" plugin
but the files are all safely stashed in their plugin file . See attached
Actually I am getting a bit peeved about being passed from pillar to post so the pmdx option is tempting, along with a package including Mach 4 licence.  A single source for the product I guess would  imply a single house solution. Either they support me  make it work or it goes back for a refund .  Not like this game ping pong I am now being part of.
Just to be clear on the application I will be using it on a Boxford TCL Lathe which is currently on Mach 3 with UC100.
Unfortunately it does not recognise the spindle pulleys function, and the threading function on Mach 3 isnt workable .
I can put up with a shortage of inputs as this is to me a learning project .  As they say "any old bike is good enough to learn on "  (daren't say that to the wife though)  I would hope though that I can move the device  on to my next project. I would hope to convert a turret lathe such as the Hardinge HC some of which are available for peanuts prices.
Maybe  in the circumstances I should consider an ethernet device ??
What lathe do you have and do these functions work on your lathe with pmdx411  ?
« Reply #6 on: January 22, 2021, 07:28:00 AM »
From the attached photo it appears that you have the files in the directory:
C:/mach4hobby
Not
C:/mach4hobby/plugins
Sorry, no backlash character on my phone keyboard.
« Reply #7 on: January 22, 2021, 08:58:32 AM »
They are indeed in the correct plugins file RHT.   They had been placed there by CNCdrive auto installer option so all OK there .
CNC drive seem beaten by the problem hence (maybe) there suggestion that Artsoft should be able to resolve .
Would be nice if someone could!!!!!
« Reply #8 on: January 22, 2021, 11:01:51 AM »
Have sent the query to Artsoft  .
Now waiting with bated breath.
« Reply #9 on: January 22, 2021, 01:41:49 PM »
if you are considering another controller for your lathe then get one with enough IO to suit your machine NOW but also
in a few years.
I don't believe any of the UCnnn series devices support lathe threading whereas the PMDX-424 does as do PoKeys, ESS and others.
