Hello
Guest
it is
August 30, 2026, 04:55:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
A and B axes
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: A and B axes (Read 13747 times)
ziga
24
A and B axes
on:
October 09, 2007, 08:54:00 AM »
hi.
I Would like to use A and B axes on my cnc mill, but i would use tham for the rotation. How do i specify that the units are not mm but °, and how can i configure mach3mill to give me a display for A and B axs like i have it for X, Y, Z, and 4?
Brian Barker
3,860
Re: A and B axes
Reply #1 on:
October 09, 2007, 09:30:09 AM »
You just tell it the steps per unit and you are good to go
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Chaoticone
5,624
Precision Chaos
Re: A and B axes
Reply #2 on:
October 09, 2007, 10:08:27 AM »
You can modify the screen set using screen 4 to add the dros.
If you could see the things I have in my head, you would be laughing too.
ziga
24
Re: A and B axes
Reply #3 on:
October 09, 2007, 01:54:14 PM »
chaoticone what you mean sreen 4 like a program, couse i have 0 experience in programing with visual basic.
Brian it is true i can set step per unit, but the defult units are mm or inch, can i set anyvere degrees, couse it would look nicer.
Chaoticone
5,624
Precision Chaos
Re: A and B axes
Reply #4 on:
October 09, 2007, 02:16:05 PM »
Screen 4 should have came with Mach. If it didn't, look in the downloads section for it. It is a program for writing screens. THere are also tutors on it as well.
ziga
24
Re: A and B axes
Reply #5 on:
October 09, 2007, 03:00:26 PM »
Thanx, i found it i just posted to soon
I didnt realise how easy it is to create costum screen
Print
Pages:
1
Go Up
« previous
next »
