Hello Guest it is November 18, 2026, 12:30:01 PM
Author Topic: Adding a second BOB  (Read 21958 times)
Adding a second BOB
« on: January 03, 2021, 02:51:46 PM »
Hello All,
My Mill has a ESS connected a 5 Axis Breakout board (BOB) driving 4 motors and spindle. The ESS has 3 parallel ports and the first one is utilized by the current BOB. How do I configure MACH 3 to utilize the second BOB?
Any help would be greatly appreciated.
Jim
Happy Milling.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Adding a second BOB
« Reply #1 on: January 19, 2021, 07:08:16 PM »
The setting is the same only the port number becomes 2
« Reply #2 on: January 26, 2021, 05:23:09 PM »
there is a choice to make that you don't get with port1.
Pins 2-9 in ports 2 & 3 can either be inputs or outputs, and the choice is made in the ESS plugin.
Port1 pins 2-9 are always outputs.
