Hello Guest it is October 30, 2026, 02:13:54 PM
Author Topic: CNC 5040 z-axis problem  (Read 102974 times)
« on: December 30, 2020, 01:14:27 PM »
Hello,
I am new with cnc, we buy from china to cut some materials. Machine x.y axis work without problem. But problem is about z-axis.
z-axis think oposite than can be.
Machine when start cut, moves down and  then cut on up not down, and after program is finish return to down.
We change in artcam material thickess and from buttom  to top, but nothing change.
we change home limits from negative to positive and oposite for z-axis ( soft max 1 and soft min -255) but nothing change
Machine z-axis negative values is on up (sealing) and positive values on floor. But why machine moves always on negative values (sealing).
How to configure mach 3, to make the machine think oposite?
Controller is XHC with wifi controler.
Offline TPS
  •  2,627 2,627
Re: CNC 5040 z-axis problem
« Reply #1 on: December 31, 2020, 12:18:57 AM »
Config -> Ports&Pins -> Motor Outputs -> Z-axis -> Dir LowActive
« Reply #2 on: December 31, 2020, 05:42:19 AM »
ok,
thanks next week try this.
« Reply #3 on: January 02, 2021, 05:32:24 AM »
we try, but not work...
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 02, 2021, 06:27:39 AM »
if you move the z-axis in Manual
pgdown -> z-axis down
pgup -> z-axis up ?
« Reply #5 on: January 02, 2021, 06:44:01 AM »
:( we work with remote, and not tested.
After Your text we test and answer is no.
pagedown z- machine goes up not down, and z+ machine goes down, not up.
« Reply #6 on: January 02, 2021, 06:49:03 AM »
we test all other axis and all move oposite diretions, where to change these to reverse?
  •  9,375 9,375
« Reply #7 on: January 02, 2021, 06:57:52 AM »
As TPS has already told you...
Config -> Ports&Pins -> Motor Outputs -> axis - change the Dir Low Active State for the particular axis which is moving in the wrong direction and save the change. Restart Mach3 to check that the changes have taken effect.
« Reply #8 on: January 02, 2021, 07:28:55 AM »
Big thanks, one big problem is reslove, key word was close mach 3 and restart again.
  •  9,375 9,375
« Reply #9 on: January 02, 2021, 09:08:40 AM »
Excellent  :)  I am pleased it is solved.
