Hello Guest it is November 13, 2026, 03:02:58 PM
Author Topic: Custom M11/M10 code headers and footers  (Read 21118 times)
Re: Custom M11/M10 code headers and footers
« Reply #10 on: December 28, 2020, 12:45:18 PM »
I'm not sure the Inkscape LaserTools extension writes code the right way for PWM. I've attached an unedited version of a test file generated by LaserTools. What do you think?
  •  9,377 9,377
« Reply #11 on: December 29, 2020, 12:16:44 AM »
That code is not absolutely right but it should work OK and that is the only important thing, although their post processor could be improved.
« Reply #12 on: December 29, 2020, 11:07:34 AM »
I tried some of the code from the Trispokedovetiles.tap file you recommended. I got it to work perfectly. The first run the on/off had some delay and the file did not cut right. As soon as I switched the output signal to active low my on/off timing with M11/10 worked perfectly!!!
Having a working G-code was the key to figuring out the mach3 set up! I have a couple more tweaks to try like changing base frequency and I think I will have it nailed.
The reason for the header and footer is basically just to have a piece of code to turn on/off the laser that is known to work properly.
The last piece of work is to ensure that the Sx commands are changing the laser output properly. I still feel like this is not working 100% as it should.
If I look at the amp meter on the laser box, shouldn't  it change based on the Sx input in the code?
  •  9,377 9,377
« Reply #13 on: December 30, 2020, 12:08:38 AM »
I am pleased to hear that you are making good progress.
Mine does. Sounds like you need to do some more work with your PWM settings.
