Hello Guest it is November 19, 2026, 05:26:38 AM
Author Topic: Homemade table with Mach 3 torch not coming on  (Read 20094 times)
« on: December 17, 2020, 07:26:12 PM »
I finally got my table running.
Inkscape
Sheetcam Mach3 post processor
Hypertherm 45xp
Home made table
Mach 3 software.
Yesterday I made my first real cut but I had to start the torch manually. It will not come on automatically as it should.
It does shut itself off at the end of the run.
I do not see a M3 code at the beginning of the program as someone on plasmaspider forum suggested.
Offline TPS
  •  2,627 2,627
Re: Homemade table with Mach 3 torch not coming on
« Reply #1 on: December 19, 2020, 12:35:44 AM »
have you set the right postprocesor in Sheetcam?
