Hello
Guest
it is
October 24, 2026, 07:29:19 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Hotkeys/Shortcuts
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Hotkeys/Shortcuts (Read 6808 times)
rhtuttle
575
Hotkeys/Shortcuts
on:
December 09, 2020, 10:45:06 AM »
As far as I can tell Mach4 keyboard plugin only allows for keys to map to jogging functions.
Is there a way to configure a key (ESC) to map to a button (btnStop) or call a macro?
TIA
RT
KatzYaakov
600
Re: Hotkeys/Shortcuts
Reply #1 on:
December 10, 2020, 01:24:57 AM »
the easy way ,if you programming in .net make some app that read any event on keyboard ,then send the command to mach by Mach4IPC.dll
jbuehn
101
Reply #2 on:
December 10, 2020, 10:45:21 AM »
You can set the function to "None" in the keyboard plugin and then assign that to a Mach input signal. Use the sig lib to do what you want when that input is triggered by your key event.
Print
Pages:
1
Go Up
« previous
next »
