Hello Guest it is October 24, 2026, 06:23:43 PM
Author Topic: Hotkeys/Shortcuts  (Read 6805 times)
Hotkeys/Shortcuts
« on: December 09, 2020, 10:45:06 AM »
As far as I can tell Mach4 keyboard plugin only allows for keys to map to jogging functions.
Is there a way to configure a key (ESC) to map to a button (btnStop) or call a macro?
TIA
RT
Re: Hotkeys/Shortcuts
« Reply #1 on: December 10, 2020, 01:24:57 AM »
the easy way ,if you programming in .net  make some app that read any event on keyboard ,then send the command to mach by Mach4IPC.dll
Offline jbuehn
  •  101 101
« Reply #2 on: December 10, 2020, 10:45:21 AM »
You can set the function to "None" in the keyboard plugin and then assign that to a Mach input signal. Use the sig lib to do what you want when that input is triggered by your key event.
